PSoC™ Creator & Designer
Hi Everyone,
I've been working with PSOC creator for the past 2 years.  I've recently run into an issue where I can't access the analog section of either PSOC3 or PSOC5 from the schematic level of the IDE.  The components are listed, but I'm getting an error when it tries to load the preview of the component in the bottom right hand corner of the screen.  I checked the containing directory, and everything looks like it is where it should be.
Has anyone encountered this problem before?  And if so, how have you managed to fix it?
Thanks in advance,
Jamie Mascola
        Hi jimmymuscles
Usually, this behaviour is happen in insufficient resources
But occasionally, happen when enough resources.
If this happen, Close workspace and re-open it
So, this problem will not happen again.
Ain't these not help for your case.
        Sorry, previous is a friendly bombing
