Hi, I started to work with PSOC 4000 Pioneer Kit and wanted to run the Cap Cense Tuner example. My environment: PSOC Creator 4.2.0.641 and CY8CKIT-040 PSoC 4000 Pioneer Kit 1.0 Rev*B. Obviously the two systems don't fit and so I had to redraw the schematic and reconfigure the two blocks (CAP Sense and SCB EZI2C). Unfortunately after trying to build the system I received an error message "SCB.h: No such file or directory". Is there any renaming or does anyone have an idea about the root of my problem? Many thanks in advance. KR, Juergen.
RyanZhao
250 sign-ins First question asked 750 replies posted
Hi Juergen, please rename the EZI2C component as SCB.
The EZI2C instance name called in CapSense_TunerHelper.c is 'SCB' by default..
Ryan
RyanZhao
Could you share the project you are using or take some screen snap shorts of the issue?
What is the instance name the SCB EZI2C? Maybe there are some mismatch on SCB instance and include files declaration.
Ryan
Hi Ryan, To my mind there should be no name missmatch. I will upload the whole project as zip file. Please let me know, if it doesn't work. Many thanks. KR, Juergen.
RyanZhao
Ryan
Hi Ryan,
Many thanks for your help. I changed the name and it built successfully. Great help. Unfortunately I only can test the software next week. I will keep you informed ☺
Freundliche Grüße / Best regards
Jürgen Päßler
Field Application Engineer
ARROW Engineering
Arrow Central Europe GmbH
Hauptstraße 103
04416 Markkleeberg, Germany
P +49 (0) 341 / 3 56 22 – 71
F +49 (0) 341 / 3 56 22 – 66
M +49 (0) 151 / 14 86 73 45
e-mail: jpaessler@arroweurope.com<mailto:jpaessler@arroweurope.com>
web:
http://www.arrow.com<http://www.arrow.com/>
Von: rzzh
Gesendet: Dienstag, 17. April 2018 04:16
An: Juergen Päßler <jpaessler@arroweurope.com>
Betreff: Re: - PSOC 4000 Pioneer Kit - Cap Cense Tuner example - SCB.h missing
<https://na01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cypress.com&data=02%7C01%7Cjpaessler%40arroweurope.com%7C32756fbf04814d975f1208d5a40925df%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636595281554781564&sdata=9H4%2FpBJ95kWdv4BqCdpDJT6Y5VS46209669cPRmtqwk%3D&reserved=0>
Cypress Developer Community <https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2F%3Fet%3Dwatches.email.thread&data=02%7C01%7Cjpaessler%40arroweurope.com%7C32756fbf04814d975f1208d5a40925df%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636595281554781564&sdata=MLq77xhZRGrU0lxkQl6CWcZSJGU2RzjoPV%2Bl8xMFlh8%3D&reserved=0>
reply from rzzh<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2Fpeople%2Frzzh%3Fet%3Dwatches.email.thread&data=02%7C01%7Cjpaessler%40arroweurope.com%7C32756fbf04814d975f1208d5a40925df%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636595281554781564&sdata=viiMUVaxZMEyXOA8mHXJzErvDu58Xo0djYZ%2FnvDg%2B44%3D&reserved=0> in PSoC Software - View the full discussion<https://na01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcommunity.cypress.com%2Fmessage%2F155638%3Fet%3Dwatches.email.thread%23155638&data=02%7C01%7Cjpaessler%40arroweurope.com%7C32756fbf04814d975f1208d5a40925df%7C0beb0c359cbb4feb99e5589e415c7944%7C1%7C0%7C636595281554781564&sdata=zWN0FojRM3WQ%2BN68zo25R5EYklPgSNzQE5SsZm72EoE%3D&reserved=0>
