Newest component doesn't show in catalog
I did a Tools->Find New Components then check "Show only newer". I then check all of the newer components found and install them. (I see errors saying the components are already on the disk because I have tried this process a few times). I then Look for the newer components in the Component Catalog and aren't listed. I specifically need Timer v2.80 and USBFS v3.20 because the design needs them and Creator says it can't find them. How do I get them to show up in the Component Catalog?
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Hi TIm,
What's the creator version are you using? What's the MPN of your device?
Did you try it on Creator 4.2? The Creator 4.2 is available in the forum PSoC Creator 4.2 Beta 2 Announcement! .
Owen
Owen_Zhang123
Hi TIm,
Owen
