Oct 28, 2021
12:55 AM
Oct 28, 2021
12:55 AM
I am troubleshooting a problem where 4.4 is not able to program or debug a project. I can program from Programmer however.
I have a suspicion that 4.2 might behave differently. Is there a way to save this specific 4.4 project so that I can open it with 4.2 and attempt to debug?
Or -
is there a way to fix this error that I get when I attempt to build that 4.4 project in 4.2:
sdb.M0052: Unable to find component "cy_boot_v6_10"
Dan
Labels
PSoC Creator & Designer Software
05:38 AM
Oct 28, 2021
05:38 AM
dame,
Hi.
To fix sdb.M0052: Unable to find component "cy_boot_v6_10" try this:
- You should see an yellow shield icon on the bottom right of the PSoC Creator window. It should look this this:
- Click this icon.
- The "Component Update Tool" window will appear
- It will list the current version of the cy_boot component as well as the later one available.
- You should be able to select "Next >".
- The window will be updated with this type of information. Select "Finish".
- This will load the newer version cy_boot_v6_10 into your project.
- The compiler build issue should now be solved.
Len
05:38 AM
Oct 28, 2021
05:38 AM
dame,
Hi.
- Click this icon.
Len
Oct 28, 2021
06:56 AM
Oct 28, 2021
06:56 AM
Thank you Len - that did it!
Oct 28, 2021
11:47 AM
Oct 28, 2021
11:47 AM
Len
