PSoC™ Creator & Designer
AbHa_1220611
New Contributor
I am using CY8CPROTO-063BLE board to test some math calculations and using the PSoC Creator 4.3 for software development.
And now I want to speed up the calculations by using the FPU. So, does anybody know how to use the FPU in PSoC6 instead of the software math libraries?
RodolfoGL
Unfortunately there is no easy way to enable FPU in PSoC Creator. You can refer to this KBA:
Enabling Hardware Floating Point Compilation for Arm Cortex-M4 in PSoC Creator™ - KBA222890
You will need to compile the project with Makefiles, instead with PSoC Creator.
If you are not using UDBs, I would suggest you to use our newest tool ModusToolbox v2.1.
RodolfoGL
