PSoC™ Creator & Designer
NeAl_2298636
New Contributor II
My project is building for more than 5 minutes. I think its because PSoC Creator is compiling everyfile even if I make a small change. Is it possible to speed this up?
Best,
Nico
Len_CONSULTRON
Honored Contributor II
NeAl,
It is my understanding that the PSoC Creator performs Incremental Builds by default.  There doesn't appear to be a Build Setting to choose "Full" or "Incremental" builds for a project.
You can force a full rebuild of your project, by selecting "Clean <projectname>" then "Build <projectname>" or "Clean and Build <projectname>".  A "Build <projectname>" will only compile changed modules.  Note:  Changing a shared header file will force a recompile of .c files that use it.
Len
Len
