PSoC™ Creator & Designer
        Hi. I am in trouble. I draft my circuit diagram dividing two pages on PSoC Creator. I want to connect an output of schematic page1 to an input of page2. Please some one show me how to connect two signal of page1 and page2. Thanks your help.
TeHe_281121
New Contributor
Hi marusan,
You connect signals between sheets using the sheet connector.
Press the 'S" key and a sheet connector will show. Wire it to the signal you want to connect to and give the signal a name.
In the connecting sheet do the same and give the signal the same name.
        HI, Thanks your good advice! After connecting the sheet connector and same signal input or output by wire tool, I could change signal name of the sheet connentor. Then, I could buid successfully.
