PSoC™ Creator & Designer
Hello Friends
This time, I am starting the work of Phase Comparator
It is very just an experimental design.
What is use it for?
Phase detector for PLL
Frequency comparator for FLL
Clock synchronization
With my DDS ...
Vector Voltage Measurement
Automatic Universal Bridge
Tuning machine for musical instruments ?
Theory of operation
This logic come from 4046 type TTL, PLL device.
That TTL has 3 type phase detectors.
PC1 is exclucive-or method
PC2 is edge detected method
PC3 is RS-flip-flop method
Each has each characteristic.
PC2 has a feature different with others.
It have wide lock-in range and available to
frequency detection not only phase-range.
This is quite getting started now,
Has many unstable behavior still
I'm not certain that can use at actually.
Thank you
        This is wave form
When sweep phase-offset from -120deg to +120deg
Bob_Marlowe
Expert II
There are some videos about "Synchronous Detection" in the library, just search for the words and look at parts 1 to 4. Probably that technique can help you with your project. When you send a mail to Chris Keeser or Dave van Ess you can ask for the complete project files.
Bob
        Bob-san, Thanks for nice follows.
I didn't see all of cypress video,
The words, "Synchronous Detection" is first time to heard.
I will be watch it as soon.
Anyway, I'm not so serious to about this module.
Because, this too much consume UDBs.
There is no practical to real use.
It's just to know what's PSoC can do.
Thank you
