PSoC™ Creator & Designer
Praba
New Contributor
I am Using the Controller CY8C29466-24SXI . In that Just Configuring the Port Pin to Turn ON And OFF the LED . But Controller Not responding its Points to Always HIGH State .
Source Code :
void main(void)
M8C_EnableGInt;
PRT2DR = 0;
VLT_CR = VLT_CR_4V5_POR;
while(1)
PRT1DR = 0x00;
PRT0DR = 0;
PRT2DR = 0;
Note : PORT Pins were Configured as Respective Global Out
Kindly Help me if I Miss anything on the Global resource Configurations Parameters
SampathS_11
Hello @Praba ,
You will have to configure the port pins individually as output, in the Pinout section. Output can be one of "Open Drain Low", "Pull Up" or "Strong".
Sampath Selvaraj
