PSoC™ Creator & Designer
Do any of you guys use GitHub for your PSoC Creator 3 workspace projects? What do you guys use in your .gitignore file? What files are neccissary and what are not? Not sure if I should ignore the /Generated_Source folder.
I'm currently considering using the below for my .gitignore:
         .DS_Store
         *.cywrk.*
         *.cyprj.*
         *.cycdx
         *.cyfit
         *.rpt
         *.uvopt
         *.uvproj
         *_timing.html
         *.cydsn/codegentemp
         *.cydsn/DP8051
         *.cydsn/Generated_Source
 No one?
HeLi_263931
Honored Contributor II
There is a knowledge base article about that: http://www.cypress.com/?id=4&rID=76644
Looks good.
If you want to keep the generated hex file (to get the binary associated with that commit without recompiling):
*.cydsn/Generated_Source/(chip name)/* !.cydsn/Generated_Source/(chip name)/*.hex
I found out the hard way, "Archive project" only stores the last 8 versions.
