PSoC™ Creator & Designer
ETRO_SSN583
Esteemed Contributor
There should be a popup warning when user has GPIO set to Global in
and then tries to set it also as a Pullup or Pulldown, ie. that it cannot be done.
Also seems ap notes do not cover this, line AN2094.
This also should be modified as it implys one could have a PU/PD on a global
net in, pic below. Same with TRM pictoral.
Regards, Dana.
