PSoC™ Creator & Designer
vama_4687281
New Contributor
   I was using  Psoc 6 series of controller for development.
I have recently downloaded the PSOC 4.3 creator  software also peripheral driver library ver 3.1.2.
     But at the time of clicking on generate application.
i am getting  following error.
1) the PDL path is invalid unable to find PDSC file.
2) The filter aborted due to error , please address all the error and rebuild.
i have also attached the image file of error
Awaiting for your reply,
Vaibhav
VenkataD_41
Hi Vibhav,
Have you given the path to Peripheral Driver Library correctly?
The default path for PDL 3.1.2 in the system is C:\Program Files (x86)\Cypress\PDL\3.1.2
You have to specify the PDL path in Tools--> Options --> Project management --> PDL V3 (PSoC 6 devices) location. Please check this once.
If still you are still getting build errors, please try with another PDL version if you have installed in your PC. This tells whether the issue is with PDL 3.1.2 installation.
Please check the above and let us know the results.
Ganesh
VenkataD_41
Hi Vibhav,
Ganesh
