Eample Project Default
ETRO_SSN583
Level 9
Level 9
If, using the example project browser, you pick a specific
family and search for an example project, if none is available
for that familiy, but is for other families, then search should
show / highlight the other applicable examples for the other
PSOC family.
When placing a SR component, right clicking it, find example project,
if user selects 5LP family no example found is reported. There is,
however, a PSOC 3 example. That should show up in the search.
Now it does not.
Regards, Dana.
Bob_Marlowe
Level 10
Level 10
Dana, something must be different between your and mine installation of Creator 3.1 SP1 dated 2/18/2015.
When I start without any project open and select from start page "Find Example Project" a Shift Reg is offered. This seems to be different from your experiences
Bob
JeCo_264681
Level 5
Level 5
100 replies posted 50 replies posted 25 replies posted
 I am also using PSoC Creator 3.1. With no project open I select under Examples and kits >> Find example project. A window opens that lets me choose the device family and then it lists available example projects.
If I try to select a device family with no project open, the project pull-down menu options are grayed out. Is your experience the same? This seems to work as I would expect it to work.
ETRO_SSN583
Level 9
Level 9
Mine are not greyed out with no project open.
Regards, Dana.
Bob_Marlowe
Level 10
Level 10
Something might be different in registry or other saved setting informations. A case for the Cypress Team?
Look at my screenshot, using win7 Creator 3.1
Bob
HeLi_263931
Level 8
Level 8
100 solutions authored 50 solutions authored 25 solutions authored
I also see the proper list of example projects, including the shift reg (it is also there for PSoC3 and 5LP). My Windows VM still has Creator 2.2, 3.0 and 3.1 installed.
