i connected an CY8CMBR3102 over the miniprog3 to a Win7 64Bit PC. The Capsense Output in EZ-Click 2.0SP1 works fine about 30 Minutes to one Hour. Then "EZ_Click has stopped working"
Whats wrong?
Regards Günter
My crystal ball doesn't show up any solution, so some more input is required: Is the chip still working (test with an additional output), does the I2C hang (skope) or does the PC application hang?
Bob
Is the chip still working Yes.
does the I2C hang No. SDA and SCL is high.
does the PC application hang? Yes. The name of the PC-Application is EZ-Click. As i said.
Even if the chip is not working or I2C hang, EZ-Click should not crash.
Günter
When you can prove that the crash of the EZ-Click program happens on different PCs I would suggest you to file a technical case, giving Cypress the same information.
BTW: When both I2C-lines remain high this will not prove that it does not "hang", it only proves that there is no communication taking place.
Bob
