Any time I feel a need to access the PC User Guide and go Help > Documentation > PC UG, it takes me to a WEB page where I have scroll down and select a language option. This gets very old, very quick. I do not understand why the manual is not kept locally.
It makes no sense that in the same Help > Documentation list, the Quick Start Guide, which normally would only be used once, it appears to t be kept locally, but the UG, key for learning the tool and minimize support questions, it is kept on line through an indirect page.
Did I missed an install option to make all the documentation resident for quick access through Help ?
Tony
Edit: Something tells me I did not miss any options 🙂 I will create/maintain my own local bookshelf.
That is the way presently you can get PC User Guide in Creator.But once you go to this WebPage-
http://www.cypress.com/documentation/other-resources/psoc-creator-user-guide
You can download the PC User guide in your system.
Thank you. I did create my doc bookshelf with access from quick launch.
