PSoC™ Creator & Designer
i want debugging with the ICE-Cube, the CY3280-20x66 board. If i start the debugger the message comes
Runtime Error!
Program: ... \PSoc Designer 5\PSoCdesigner.exe
abnormal program termination
after that
Could not detect the pod
1. ...
I'm working with
PSoC Designer Content 5.1 (SP1.1)- Build 2110 - 29-March-2011.14:20:08
PSoC Designer Core 5.1  (SP1.1)- Build 2110 - 29-March-2011.14:20:08
PSoC Designer Documentation 5.1 (SP1.1)- Build 2110 - 29-March-2011.14:20:08
Thanks for help.
HR
Dear Hubert,
your problem should go directly to our support team. There will be some interaction between you and the team to resolve your issue. Please file a tech support case.
Once you are logged into Cypress please follow this link to create a support case or check the attachment how to navigate to the support from the Sypress home page.
Thank you for using Cypress and our team is here to help.
Robert
