Creator "Error: multiple definitions of component " while porting a project
When I open a project created in creator 2.0 to creator 3.0, I get error saying 'multiple definitions of components'. How to remove this error?
Ans:
when you have added additional library directories to your project and have not changed the tool chain correctly, you may get this error.
Go to Creator menu->Project->Build Settings->Linker->Additional Library Directories. And edit the directory ARM_GCC_441\Debug as ARM_GCC_473. It will fix this error.
