PSoC™ Creator & Designer
FaBi_2763241
Contributor II
Dear all,
any suggestion on how I could configure SPI in Creator to send serial data to chips like led drivers
which don't have a dedicated clock line but utilise a NZR signal with tight timing constraints. these are found increasingly in cheaper addressable led strips than those with Data/Clock serial drivers.
I am using the PSoC 4 BLE mcu.
Fausto
FaBi_2763241
Contributor II
Thanks for these links, they seems interesting but I need to test their suggestion when I find time.
I currently use SPI, a timer and a clock component for regular SPI protocol chip and it works without problems
I guess the solution is not too far away for the clockless chip hopefully.
AnkitaS_51
Please create new thread for any further queries
