Cannot make a LED work
        I am starting to use the device CY8C20666A-24LTXI with PSoC Designer 5.0.
I can program it using miniprog3, but I can't succeed to light a LED (using LED user module). Is there a problem in my code? Is there a common mistake I could have done?
You can look at my project too.
Thanks a lot.
Gabriel
// C main line
#include        // part specific constants and macros
#include "PSoCAPI.h" // PSoC API definitions for all User Modules
#include "PSoCGPioInt.h"
void main(void)
// Enable global interrupts
M8C_EnableGInt;
//LED initialisation
LED_0_Start();
LED_1_Start();
LED_0_On();
LED_1_On();
// Main operating loop
while (1)
LED_0_On();
LED_1_On();
MR_41
First like received
        I am not able to open the attached project. Check if the pin configured for the LED is StdCPU / Strong drive mode.
