It's the first time I use creator. I copy a project from my colleague computor. It can build successfully in his computor, but turns out to be a lot of errors in my computor. Might it be some setting problem in my creator?
Probably you busted the available flash with your code size. You did not tell what IDE you used, Creator I assume, but which version?
Did you use assembly code and are the errors you took the pictures from of the first errors/warnings?
Bob
Bob
Post the poject here for us to check. It would be easiler that way.
I use Creator v2.0. There are two kind of error, which are the two pictures I posted. You know how to fix the error with no space?
