Hi all,
Is there a way to calculate the execution time of a routine or part of a program (between two breakpoints)? Such as a stopwatch or so?
I hope anyone can help!
Rob
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
A simple way is use a scope, and flip a pin at start and end of code segment
of interest. Or use a counter with a know period, and read it at start then again
at stop of code segment, and subtract the two readings.
Or you can look at .lst file and count code cycles, tedious.
Regards, Dana.
Thanks Dana,
Then I will use the scope method.
In MPLAB (PIC IDE) there is a stopwatch available, very easy to use.  Maybe an idea for Creator....?
Thanks!
Rob
Bob_Marlowe
Level 10
Level 10
Not too difficult to program one, Just a timer, a clock and an interrupt...
Bob
ETRO_SSN583
Level 9
Level 9
Your always welcome !
Dana.
