PSoC™ Creator & Designer
DaSi_281136
New Contributor II
Is there a way to to determine the run time of a function?
Normally I'll toggle a pin at the beginning and end of a function and measure with a scope.
That's obviously not a perfect solution as it includes the time to toggle the pin.
I figured there was a way to do this via Creator or during a debug run.
odissey1
Honored Contributor II
DaSi,
You didn't mention processor type.
On PSoC4 and PSoC5  you can use a custom component StopWatch to measure elapsed CPU clocks
Re: How to get timestamp in microseconds using Psoc5lp
And for PSoC6
Measuring cycles using DTW on PSoC 6(M4)
/odissey1
odissey1
DaSi,
And for PSoC6
/odissey1
DaSi_281136
New Contributor II
Thanks for the reply.
I'm using a PSOC5LP.
I'll take a look at using the stopwatch.
I'm hoping to the be able to get nanosecond resolution.
odissey1
The StopWatch accuracy is 1 BUS_CLK, which at 80MHz translates into 12.5ns.
/odissey1
