PSoC™ Creator & Designer
puga_4644901
New Contributor
PSoC creator has  CY8c4147AZI-s445 64-TQFP device in list but
PSoC creator does not have CY8c4147AZI-s445 48-TQFP device in list so,how to get support for CY8c4147AZI-s445 48-TQFP?
MotooTanaka
Esteemed Contributor
I have just checked the PSoC 4 : PSoC 4100S Plus Datasheet...
may be you can work around doing
(1) Select device as CY8c4147AZI-s455
(2) Use only pins exists on the 48-TQFP, such as P0[0:7], P1[0:7], P2[0:7], P3[0:7], P4[0:3], P7[0:1], XRES
(3) Program the module as CY8c4147AZI-s455
moto
P.S. I checked the ASR6501 Datasheet,
it's not a PSoC but has LoRa and (probably) PSoC inside the package.
https://www.electrodragon.com/w/ASR6501
GitHub - asrlora/alios-asr-lora
