PSoC™ Creator & Designer
DaHu_285096
Contributor II
 I was working on a project happily for an hour or so writing code and testing with the MiniProg3.
Now for some reason? The brakpoints cannot be set. When I attempt to run the code the breakpoints change from solid to just a circle outline.
Once again, I have am not aware of making any changes to settings, only the code I am compiling in main.
The target is PSOC 4 this time. Is there some hidden gotcha I need to read about this too?
DaHu_285096
Contributor II
 OK, I found it. My mistake. Thanks
Bob_Marlowe
Expert II
Despite from "How did you find out" my question is :"What did you do?"
Bob
HeLi_263931
Honored Contributor II
Crystalball guess: some forgotten breakpoints in already closed files (and in places that were not reached at time of testing). Happened to me before 😞
DaHu_285096
Contributor II
 Yes, exactly.
Silly mistake, not an actual break point but an infinite for loop I had not removed ... for(;;)
