Asynchnous Operation of PSoC Components
LeBa_1250741
5 sign-ins First solution authored 5 replies posted
I have tried a couple of UDB components that use counters, but it seems they are synchronous to the Bus_Clock.
Our application needs an async clock, as digital PLLs generally create too much jitter (or conversly we may want to run a slow system bus to save power but run a UDB module at high speed)
I attempted to look into the PWM component for example, but the UDB/Verilog files aren't present in the library.
Can anyone tell what PsOC components are synchronous to the system bus clock, and which ones are asynchronous?
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
The basic counter in Digital, Utility.
Regards, Dana.
