When using the AMuxSeq component in muxtype "single mode", the API does not generate a next function to handle the mux channels.
How to switch the channels otherwise?
PSoC Creator Software
To see the implementation of the Amux next funciton in case of single ended mode, kindly check the cyfitter_cfg.c generated sources. This is actually similar to differential configuration where the functions AMuxSeq_1_CYAMUXSIDE_A_Next(), AMuxSeq_1_CYAMUXSIDE_B_Next() will defined inside the cyfitter_cfg.c file. Regardless of all these you can confirm this just by calling the funciton in the main.c file.
Vasanth
Which device are you testing in ? When I tested at my end I could find the next function getting generated. Will you be able to share the configuration ?
Vasanth R S
I'm working with a CY8C5868AXI, with PSoc Creator 4.2.0.641.
I can see from the code that the next function is explicitely disable when not using differential inputs:
#if (AMuxSeq_1_MUXTYPE == AMuxSeq_1_MUX_DIFF)
* Function Name: AMuxSeq_1_Next
void AMuxSeq_1_Next(void)
AMuxSeq_1_CYAMUXSIDE_A_Next();
AMuxSeq_1_CYAMUXSIDE_B_Next();
Vasanth
