PSoC 6
JeHa_3912621
New Contributor II
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build Project 'M4' - Target 'Target 1'
linking...
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(126): warning: L6314W: No section matches pattern *(.cy_app_signature).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(136): warning: L6314W: No section matches pattern *(.cy_em_eeprom).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(145): warning: L6314W: No section matches pattern *(.cy_sflash_user_data).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(154): warning: L6314W: No section matches pattern *(.cy_sflash_nar).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(163): warning: L6314W: No section matches pattern *(.cy_sflash_public_key).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(172): warning: L6314W: No section matches pattern *(.cy_toc_part2).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(181): warning: L6314W: No section matches pattern *(.cy_rtoc_part2).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(191): warning: L6314W: No section matches pattern *(.cy_xip).
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\cy8c6xx7_cm4_dual.scat(201): warning: L6314W: No section matches pattern *(.cy_efuse).
Program Size: Code=13182 RO-data=2174 RW-data=692 ZI-data=109224
Finished: 0 information, 9 warning and 0 error messages.
FromELF: creating hex file...
After Build - User command #1: C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\postbuildCortexM4.bat "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\" "cmsis" "C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\win\elf"
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>IF /I "cmsis" NEQ "cmsis" GOTO not_cmsis
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>copy /Y "C:\Keil_v5\ARM\PACK\Cypress\Pack\2.0.0\Device\CY8C6347BZI-BLD53_Pack\Other\win\elf\cymcuelftool.exe" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe"
已复制         1 个文件。
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>move /Y "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf" "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf"
移动了         1 个文件。
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>for %i in ("E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\Objects\*_link.axf") do @(IF "%i" NEQ "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf" set MergeFiles=!MergeFiles! "%i" )
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>set MergeFiles="E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf"
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>"E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe" --sign "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_link.axf" --output "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf"
No ELF section .cychecksum found, creating one
Application checksum calculated and stored in ELF section .cychecksum
Checksum calculated and stored in ELF section .cymeta
E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild>"E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\\cymcuelftool.exe" --merge "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\\M4_signed.axf" --output "E:\Work\18.reflex-PPG\Software\Cypress-Prj\Cy-V0.001\VitaBle.cydsn\uVisionBuild\ObjectsM4\M4.axf"
Expected at least 2 elf file arguments for -M/--merge
Usage:
Display help:
   cymcuelftool -h/--help
Display version information:
   cymcuelftool -v/--version
Display memory allocation by type:
   cymcuelftool -A/--allocation file.elf
Merge ELF files:
   cymcuelftool -M/--merge complete_app1.elf complete_app2.elf ... [--output merged.elf] [--hex merged.hex]
Sign ELF file, with option for secure (encrypted) signature:
   cymcuelftool -S/--sign unsigned.elf [<SignScheme>] [--output signed.elf] [--hex signed.hex]
Generate Patch file:
   cymcuelftool -P/--patch file.elf [--encrypt <Cipher*> --key key.txt [--iv iv.txt]] [--output patch.cyacd2]
   *NOTE: RSAES-PKCS and RSASSA-PKCS not allowed for this command
Create Code sharing file:
   cymcuelftool -R/--codeshare file.elf symbols.txt <GCC/ARMCC/IAR> [--output shared.s]
<SignScheme> is only used for signing the user application. It must be ONE of:
   1) HMAC <Hash*>  --key key.txt              (*CRC not supported)
   2) CMAC-AES-XXX* --key key.txt              (*XXX can be 128, 192, or 256)
   3) <Hash> [--encrypt <Cipher> --key key.txt [--iv iv.txt]]
<Hash>: CRC, SHA1, SHA224, SHA256, SHA384, SHA512
<Cipher> (requires key):
   Public-key: RSAES-PKCS, RSASSA-PKCS
   Symmetric:  DES-ECB, TDES-ECB, AES-{128|192|256}-{ECB|CBC|CFB}
key.txt: ASCII text file containing key appropriate for chosen Cipher. May be symmetric hex key or PEM format for RSA cipher variants
iv.txt:  ASCII text file containing initialization vector for certain encryption algorithms
".\ObjectsM4\M4.axf" - 0 Error(s), 9 Warning(s).
Build Time Elapsed:  00:00:02
RyanZhao
I think you're using µVision 5, when you exporting, select  CMSIS-Pack Projects
RyanZhao
Hi Jerry, Could you double-check your project exporting with using PSoC Creator?
PSoC Creator's help file provided good guidance on this exporting. Please do not ignore any steps described in the help menu.
RyanZhao
Top labels
