I am using PSoC 6 BLE Pioneer Kit. regarding my application, I need to have a digital output on P8[0] to P8[8] but it didn't work I tried the same program on other ports like P5[0] to P5[6] I got the digital output and it works fine. since I need a high number of digital output in my work, how can I make P8 work?
PSoC 6 MCU
Hi @iabdelsalam ,
The pins P8[0] to P8[7] are not connected to the header J20 of the PSoC 6 BLE Pioneer Kit by default but instead to the capsense pad as mentioned on page 14 , of the CY8CKIT-062-BLE PSoC 6 BLE Pioneer Kit Guide as shown below:
You will have to make the hardware connections as mentioned above to be able to use the pins on port 8 as GPIOs.
Hope this helps!
Warm Regards
Alen
Hi @iabdelsalam ,
Hope this helps!
Warm Regards
Alen
thanks, Alen
I will do the hardware connections
