Hello
I need a C# app ( Windows Form Application) to communicate between PSoC 6 and PC
Actually i want to send a text from PC and receive from Device
Please help me!
Note: I can't use CySmart windows App because i don't have the special dongles!
It is recommended to use only Cypress BLE Dongles to communicate between PSoC6 BLE and PC. So, you have to use Cypress dongle CY5677 CySmart USB Dongle to make connection.
Please refer to this thread link for example code on sending/receiving data from PSoC6 BLE.
P Yugandhar.
mayo,
To clarify your question: Do I assume correctly you want some sort of UART terminal-like feature using BLE between the PSoC6 and the PC?
Len
Yes, exactly, a wireless connection between PSoC and PC via Bluetooth
On Sat, Mar 7, 2020, 20:24 LePo_1062026 <community-manager@cypress.com>
mayo,
In your case, it might be easier than needing a C# application. There are many Terminal programs out there for the PC. What you need is a .ini file that associates the BLE port with a COM assignment.
Len
hi again that part is not my question.
let me explain better
I want to send text from my phone or PC (from the CySmart app/tool) and receive it in PSoC
I would greatly appreciate if someone give a example code or a little help to do that.
thank you so much
P Yugandhar.
