I have a project with PSOC 6, recently I did a merge from my teammate and i start to get this error during compilation, I am not able to fix the same please help me solve the same.
Failed while attempting to update project 'QBL_PSOC': Could not find a part of the path 'C:\Sandbox\QBL\bitbucket\qbl_v3_firmware\QBL_PSOC.cydsn\Generated_Source\PSoC6\pdl\cmsis\include\arm_common_tables.h'..
I am aware that the generated code in the above path does not have the cmsis but I am not sure why the code is not generated even when I chose the option Build->Generate Application.
Suman
PSoC 6 MCU
I deleted the folder "C:\Sandbox\QBL\bitbucket\qbl_v3_firmware\QBL_PSOC.cydsn\Generated_Source" and regenerated the code it worked.
No, I am not able to build the project I get the below error -
Hi @Sunny,
Do you observe the same with other projects?
Can you try to clean the project, and rebuild it again?
If you have changed the TARGET in the Makefile manually, try to perform the same using Library manager, or regenerate the launch files.
Let me know if the above helps.
Nikhil
I did try to clean,rebuild and also did uninstall and reinstall tools.
I see a error as now as -
"Failed while attempting to update project 'QBL_PSOC': Could not find a part of the path 'C:\Sandbox\QBL\bitbucket\qbl_v3_firmware\QBL_PSOC.cydsn\Generated_Source\PSoC6\pdl\drivers\peripheral\scb\cy_scb_common.c'.."
No target changes are made.
Screen shoot of error -
Hi @Sunny ,
I observe that your initial error has been resolved. Now you are facing error in the scb folder.
Can you manually navigate to the path "C:\Sandbox\QBL\bitbucket\qbl_v3_firmware\QBL_PSOC.cydsn\Generated_Source\PSoC6\pdl\drivers\peripheral\scb\cy_scb_common.c" and verify if the scb folder and cy_scb_common.c are present?
Nikhil
