would like to have an very simple example how to share variables between CM0 and CM4 cores.
variable "a" should be used in cm0p.c and cm4.c
I have already read about IPC, but dont understand yet how it works.
It is a lot of code in examples, i am confused
There is no project to upload, because i have just started an new schematic with 1 LED from cy8ckit-062 kit.
I want toggle varible a i cm0p.c and act in cm4.c.
Can please anyone help?
Thanks and best regards
Alex
Hi info_1585471,
I checked your code. The issue is that your variables have been assigned different memory locations in each of the cores.
(.map file in results)
cmoplus:
.mysection 0x08020000 0x4
*(.mysection)
.mysection 0x08020000 0x4 .\CortexM0p\ARM_GCC_541\Debug\main_cm0p.o
0x08020000 Blue_On
0x08020001 Red_On
0x08020002 SW2_button
0x08020003 Green_On
CM4:
*(.mysection)
.mysection 0x08020000 0x4 .\CortexM4\ARM_GCC_541\Debug\main_cm4.o
0x08020000 SW2_button
0x08020001 Blue_On
0x08020002 Red_On
0x08020003 Green_On
You can force contiguous memory locations by putting all these into a structure or you may have to define separate sections in your linker file for each variable.
I have added the modified project where I have defined a structure for all the variables and your code worked as expected
volatile struct
uint8 Green_On ;
uint8 Red_On;
uint8 Blue_On ;
uint8 SW2_button;
}check CY_SECTION(".mysection");
Bragadeesh
Hi Alex,
Please check this link, it will be helpful:
https://www.cypress.com/documentation/code-examples/ce216795-psoc-6-mcu-dual-core-basics
Hello Ankita,
i have allready seen the reply from Mark, and his example from here Re: How to set up shared memory between CM4 and CM0p
works.
But if i modify it a little bit, it doesnt work anymore.
I have attached my really simple project.
It is running on psoc6 wifi-bt kit.
I am really confused, why it is not running well, would be glad if somebody can check it.
Thanks very much.
Alex
There are two code examples that use the IPC low level driver to implement high level abstraction concepts - Pipes and Semaphore. They are way simpler.
https://www.cypress.com/documentation/code-examples/ce223820-psoc-6-mcu-ipc-pipes
https://www.cypress.com/documentation/code-examples/ce223549-psoc-6-mcu-ipc-semaphore
Hope this helps.
Hi info_1585471,
cmoplus:
*(.mysection)
0x08020000 Blue_On
0x08020001 Red_On
0x08020003 Green_On
CM4:
*(.mysection)
0x08020001 Blue_On
0x08020002 Red_On
0x08020003 Green_On
volatile struct
uint8 Green_On ;
uint8 Red_On;
uint8 Blue_On ;
uint8 SW2_button;
Bragadeesh
