PSoC 6
peya_1337906
New Contributor II
Hi ,
     When I build PSoC6 project, sometimes it appear build error: "Hex file generation step failed, see output window for more information."    If  choose clean and build , will be successful.   But it need more time to build all files.   When I modify any software , such as main.c file, build error again.  I don't know the reason.
ShipingW_81
Perry,
Do you mean it always fails for re-building? Can you show the error log in the output window? maybe need you attach your test project here.
peya_1337906
New Contributor II
Hi WangS,
     It not always fail for re-building,   occasionally failed.    Sometimes, if modify ".c" or other, re-building failed,  but clean and build will be OK.  Errors are more likely to occur.   If use code example, sometimes also fail.
Roy_Liu
Check whether the resolutions for this build error issue in other threads are helpful for you.
Creator error Bulding Psoc6 Hello World Project
Build Failed
Roy Liu
Top labels
