PSoC 6
GrahamS_21
Do we have any guidance on how often the PILO should be trimmed against a high accuracy clock source to maintain a 250ppm accuracy?
This would be for the PSoC 6 module, with the AltHF BLE ECO of 32MHz as the high accuracy clock source.
Do we have any example code to do this as well?
Graham
ShanmathiN_06
Hi Graham,
We do not have any code example as such.
But you could refer to the PDL documentation: System CLock-> Clock Trim (ILO, PILO)-> Functions. The function usage under Cy_SysClk_PiloTrim() trims the PILO with ECO.
You could change the ECO to AltHF clock for your application. You need to change CY_SYSCLK_MEAS_CLK_ECO to CY_SYSCLK_MEAS_CLK_ALTLF in the Cy_SysClk_StartClkMeasurementCounters() API.
You can also click on the API and refer to enum cy_en_meas_clks_t to know all the possible clock sources.
I hope this helps.
Shanmathi
ShanmathiN_06
Hi Graham,
I hope this helps.
Shanmathi
GrahamS_21
Do we have any guidance on how frequently we should be calling these functions to maintain the accuracy?
thanks
graham
ShanmathiN_06
Hi Graham,
It is generally recommended to calibrate every 0.1 to 1 second to maintain the accuracy.
Shanmathi
Top labels
