In PSoC Creator, the FSUSB component (v3.20) is marked as incompatible with PSoC6.
Since the FSUSB component doesn't work, what is the recommended way to implement USB device functionality on a PSoC6?
Linus
To have an early access to the USBFS PDL, you might want to register for the Modus Toolbox and be a beta tester.
http://www.cypress.com/products/modustoolbox-integrated-design-environment-ide
For the PSoC Creator component, you will need to wait till September.
Hi Linus,
We are working on the USBFS PDL driver that will be released in the next version of the PDL. We are also going to provide the USBFS component for PSoC Creator.
The plan is to release the component in September of this year.
ouch! same here, we would need something this month 🙂
can we get a beta drop?
I've registered about 2 months ago. Still no access...
Can't we just get a zip or a git-repo to the driver code needed for usb?
we can make it work in PSoC Creator too.
Thanks!
Hi David,
Are you in contact with anyone from CY about your requirements? Yes or no, could you please send me a message and I will try and support what you need.
Michi Yoneda
