- Email to a Friend
Is it possible to debug both cores simultaneously in uVision 5.28a? This KBA (PSoC 6 MCU Multi-Core Debugging with Third-Party IDEs – KBA222959 ) notes that Eclipse is able to do it. Can uVision? And what debugger tools work for this task?
- Email to a Friend
Yes it can be done. You need to have two instances of the tools running and each debugs one of the cores. Please follow the PSoC Creator help topic "Creating uVision Projects for PSoC 6" in Help > PSoC Creator Help Topics.
Also, you need to take care of some of the settings to make sure they work correctly which is explained in the following video: Application Note 318: Multi-Core Debugging with MDK
You can use Ulink2 or JLink which are the supported debuggers for PSoC6 in Keil uVision.
Dheeraj
- Email to a Friend
Dheeraj
- Email to a Friend
Can you clarify the procedure for having 2 uVision instances running and how they can both attach to the same Ulink2 or JLink?
Are 2 debuggers needed, or just 1?
- Email to a Friend
You will just need one debugger. The procedure is mentioned in the video link I provided in the previous interaction.
Dheeraj
