PSoC™ 6
susc_3824531
New Contributor
Can I write into the SRAM of the PSOC6? I need help in changing the contents of the sram
LinglingG_46
uint8 address=0x80;
*((uint8*)address)=content value;
You can replace the 0x80 with the address you want to operate.
LinglingG_46
uint8 address=0x80;
susc_3824531
New Contributor
Thanks Ring,
I am not able to locate the actual physical address of the SRAM. Is there any datasheet of the PSOC6 BLE-63, that mentions the starting address of the SRAM. And also can I power down all the blocks of the SRAM?
LinglingG_46
Maybe the below linker question can make sense for you:
Trouble setting a memory watchpoint with a specific value
Top labels
