I am trying to write a DFU application. I am calling Cy_DFU_ExecuteApp(1), but my App0 keeps restarting in a loop.
I have built a simple project that a simple project that reproduces the issue. At the end of the App1 build, both build outputs get merged into one. Then I program the merged output to my psoc 6. Then, in debug without programming, I change the value of switchToApp1 to 1 to call Cy_DFU_ExecuteApp(1), but I get back in App0.
What am I doing wrong?
You have missed the following function in main.c of CM0+ core:
* Function Name: Cy_OnResetUser
* Summary:
* This function is called at the start of Reset_Handler(). It is a weak
* function that may be redefined by user code.
* The DFU SDK requires this function to call Cy_DFU_OnResetApp0() in app#0
* core0.
* Parameters:
* None
* Return:
* None
void Cy_OnResetUser(void)
Cy_DFU_OnResetApp0();
Please include this in your applicaion and check once. Also, please refer code examples on DFU for PSoC 6 in PSoC Creator.
Ganesh
* Summary:
* core0.
* Parameters:
* None
* Return:
* None
Ganesh
