CY8CKIT-062 WIFI cannot use I2C by Bridge Control Panel
QiLu_3389441
   I just try to test the I2C followed the step of PSoC 6 101: Lesson 2-3a Basic I2C Implementation.
   In the panel, I just can see the com port, but no Kitprog2 on the list.
   I check the manual, there is the introduction of The KitProg2 can function as a USB-I2C bridge, so it supposes to work.
   What's the problem?
It looks the kitprog2 port is not shown in control panel port list. Please check the device manager in your platform whether kitprog2 is shown, just like attached capture(under 'Ports' list).
If not shown, please check if the correct mode is on by SW3 on the board.Capture_kitprog.PNG
ShipingW_81
Please make sure you have select the 'Protocol' as 'I2C' in the control panel GUI. otherwise, I2C interface would not show.
   But the protocol I2C is not selectable, thx
Hi, the problem is the SW3, thx
