PSoC™ 6
I'm testing the CE219881_PowerModes example code by CY8CKIT-062-BLE kit.
I want to monitor the current consumed by CM0+ and CM4 but I can't find the jumper PWR_MON in the kit as described in P.4 CE219881.pdf
I believe CY8CKIT-062 and CY8CKIT-062-BLE is different kit, but it seem CY8CKIT-062 is not available.
Please tell me a way to monitor current consumed in CY8CKIT-062-BLE kit ?
The board layout may have changed between the release of the code example and now. Please check the bottom of your board. The PWR MON jumper should be in the middle.
Thank you!
I was able to monitor the current.
By the way, please tell me if you have any extended project that show the consumed current  value in PC terminal for each mode changing.
Eg. using ADC to convert the consumed current and send it through UART.
Regards.
Top labels
