PSoC™ 6 SDK
austin_h
10 sign-ins 5 questions asked 5 sign-ins
As title. If PSoC 6+CYW43012 be BLE peripheral role.
and how many central devices (such as smart phone or others) can connect to  CYW43012 be BLE peripheral???
Austin
Owen_Zhang123
Moderator 500 solutions authored 250 sign-ins 1000 replies posted
We don't have the test data for it. You may need to test it by yourself.
Yes, the parameter is generated from cycfg_bt.cybt.
You also need to set the parameter ble_max_simultaneous_links in cycfg_bt_settings.c.
Owen_Zhang123
There isn't a specific number in the FW. The maximum connections is depends on the memory size and your application. You can test it based on your own application.
austin_h
Hi Owen:
If Based on SDK sample code AnyCloud_BLE_Battery_Server. May I know the max number??
Is it define in CY_BT_SERVER_MAX_LINKS(cycfg_gap.h)??
Austin
Owen_Zhang123
