where can i find the project of CE62828
YoDe_1666546
First question asked First reply posted First like received
where can i have the zip project of this example https://www.cypress.com/file/108526/download i have configure all manually but i cant get it work
Len_CONSULTRON
Level 9
Level 9
YoDe,
I could not find a project archive for this CE62828 either.
Were you able to locate CyUSB.sys and CyUSB.inf files mentioned in the pdf?
You mentioned you can't get it to work.  I assume you got it to compile.  Is that correct?
Len
Len
i can't compile it and yes i have found the drivers and the usb suite
YoDe_1666546
i´m already compile it and program the psoc but i can't install the driver
YoDe,
Are you will to share your project on the forum?  Maybe I can reproduce the same results and propose a solution.
Len
Len
