using timers, PSoC
AmCi_3754291
Hey,
Probably a nube question but here it goes.
I was trying to use a timer to time stamp the occurrence of a task in my application.
I tried starting from the iotExpert project that I found here: https://iotexpert.com/2017/05/17/psoc-5-timer-circuit-debug/
However, I never seem to get a counter reading. My period is always 9999 and I can't figure out what I'm doing wrong.
Please find attached a bundle of my project
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I think you assumed that the initial level of Channel_1 is low with
But since it's an open drain bidirectional, I'm afraid that you need an external pull down or external signal attached.
So I changed the Channel_1 to a Resistive pull down
Then your program seems start working.
If you had an external signal attached to the pin, may be the initial project was also working.
moto
MotooTanaka
Level 9
Level 9
moto
