usb
hello
    I have a question need your help, I use psoc3.
   question is :
       I made a signal acquisition system, using ADC and usb, but the result is bad.
   So, I want to use the DMA and usb, but don't know how a configuration of both?
  thank you!
                                                           songyu
Refer to the Application Notes USB Peripheral Basics - AN57294 at http://www.cypress.com/?rID=39327.
You need to configure your PSoC as a bulk device that transmits data to the host(PC) continuously. The DMA has to be
configured to have ADC as source and a memory buffer as destination.
Refer to this Application Note to learn about DMA Using DMA on PSoC® 3 / PSoC 5 - AN52705
http://www.cypress.com/index.cfm?rID=37793
