i'm playing around with the ADC on the PSOC3, i've got the CY8CKIT-030. My Problem is even if i connect my input GPIO (P4.6) to VSSA, the rawvalue is very rough. It jumps around between bit 30 and bit 40, i expect a more stable value. Is it possible to get the noise smaller, so that it is stable on +-1 bit?
Sure a external voltage reference will help, i will try that, but isnt it possible to get more stability with the internal reference and without a filter?
I'm using:
-resolution: 16 Bit
-conversion mode: 2
-rate 2000sps
-input mode: single
-buffer gain: 1
-buffer mode: rail to rail
-Vref: internal bypassed on P0.3
-clock: internal
my code:
void main()
Initial();
while(forever)
ADC_StartConvert();
ADC_IsEndConversion(ADC_WAIT_FOR_RESULT);
Rawdata = ADC_GetResult32();
sprintf(Buffer, "%ld", Rawdata);
UART_PutString (Buffer);
UART_PutCRLF(0x20);
so i get my rawdata displayed in my terminal.
PSoC 3
If you have a hi res adc there is no end to the challenges to getting
low noise results, 16 bits with a 2V reference is 15 uV for 1/2 LSB.
Start by looking at your overall noise by using scope on infinite persistance,
and look at supply rails and inputs. That will give you the pk-pk noise you
are facing.
Here is an ap note on PSOC 3 ADC -
http://www.cypress.com/?docID=30483
More reference material that you want to know, attached.
Regards, Dana.
are facing.
Regards, Dana.
Some additional thoughts.
If you look at power supply rail typical 200 mV+ of noise, with a 30 uV
LSB, thats ~ 6700 lsbs of noise in the system. PSRR of components can help,
but you can see a little bit of noise goes a long way to complicating sample
to sample readings.
Use differential measurements whenever possible, the CMRR of the diff amp, ADC
front end, will help with rejection and CM signal pollution. Clock the ADC at a multiple
of the decimator response frequency, specifically the zeroes, that helps with CM noise
suppression.
Look at the caps you use to suppress noise, polymers an order of magniitude better
Z(f) response. Ceramic disk as well, actually look at datasheets, not all caps are equal
in their ESR curves.
Regards, Dana.
You didn't tell about using a bypass cap at port 0(3) did you connect one?
Bob
okay thanks - an external voltage reference and basically the difference mode helps to come close to my expectations. I had configured already an external bypass capacitor.
Now the values varies between -4bit and -7bit. Next i will try to add a lp-filter...
For now i'm happy - thanks a lot!
