Hi all,
If a port is connected to a signal generator, can I still use uint8 Pin_Write(void) function to set the value of that port to the other value for some certain time period, like 0. Thank you so much!
PSoC 5LP
Yes, the pin logic is not a f() of the signal injected into
it, but you could get unexpected results. For example,
if you are driving the pin with 50 ohm generator, and you
config pin as strong drive output, you could get high currents
flowing that PSOC I/O supply routing on die cannot handle.
Hence logic could fail, part could get damaged. Case in point
you drive output to logic low and generator to supply rail.
Regards, Dana.
Clarify this that when pin is subjected to inappropriate conditions
then pin logic can fail, stated another way pin logic then would be a
function of the way you drive it.
Regards, Dana.
First: the function is void Pin_Write(uint8).
You cannot safely run two signals against each other when their type does not match,
When the output of your function generator is open drain or a resistive output there is a good chance to get it to work as you like to. When the generator's output has a phase of high impendancy you may drive the signal by the pin, there is a output enable signal to swithch a pin on and off.
Plenty of possibilities, but some combinations may blow your pin or generator.
Bob
Thank you for your help! Yup! I can't feed two conflicting signal to a pin.
