PSoC™ 5, 3 & 1
        i am working on a project wich requries a use of a pwm signal can anyone give me the performance comparision??
 I was curious too.. i found that pwm provides u with more flexibility.. what is ur application? ( i am using-030) bt i can maybe give u a generalized performance according to ur app!!!
But for me... PWM is the best!!
ETRO_SSN583
Esteemed Contributor
Performance comparison to what ? What are you trying to do ? What is
the goal of the design, its functionality your are seeking, clearly forum
needs a little more info to help you.......
Regards, Dana.
        I have worked on both...and I'd recommend using TRIM......though it is a bit more complex than PWM, it provides a more accurate result.
ETRO_SSN583
Pros and cons to either approach.
1) TRIM confined to 8 bit resolution, PWM to 16 bits, PriSM to 32 bits.
2) TRIM more outputs available.
3) PriSM less clock noise.
Regards, Dana.
ETRO_SSN583
Just an FYI, you should post in the PSOC 3 forum as that is the
device you are working with.
Regards, Dana.
