hi developers,
i am exploring the generic switched capacitor block in PSoC1. the switched capacitor block parameter list does not include a frequency selection option. is it user configurable? if so where can i find the frequency of switching. because for my design i need the input resistance value which is calculated as 1/(capacitance*switching frequency).
PSoC 1
The block (column) in a PSoC1 has an input for a frequency you have to select.You may use VC1 to 3, sysclk or any self-generated frequency (with a timer/counter/PWM) or even an externally supplied frequency. When you drop a SCBLOC on your chip-area you find the clock-selection on the right of the column consisting of two parts: a 4-1 mux and two 1-16 muxes giving you approximately 35 different clock sources.
Happy clocking
Bob
Happy clocking
Bob
Note that the maximum analog column clock frequency specification is 8MHz. That means, the maximum allowed switching frequency in SC blocks is 2MHz (8MHz/4).
