PSoC™ 5, 3 & 1
Hi:
As my experiment on EZI2C.
1) PSoC3 I2C_CSR.bit3 (address)  (0x49d7) was descripted in TRM as be cleared by firmware writing '0'.
But in EZI2C_INT.c generated by creator,  ISR function never write this bit  '0' to clear it.   Is this bit will be cleared by any accessing instead of writing '0' ?
2) The I2C interrupt mask never be mentioned in TRM, it seems built in UDB, is it?  If any MASK register exist, what's the initial/reset value, since I have not found any configuration in EZI2C_Start().
B.R
