hi
i am new in cypress..i bought a psoc1 board and a miniprog 3 programmer..i install psoc designer in windows 7 pc, when i compile i am getting an error like this
Starting MAKE...
creating project.mk
name translation failed on C:/Program\ Files\ (x86)/Cypress/PSOCDE~1/5.4/Common/CYPRES~1 - 3
name translation failed on C:\Program - 2
name translation failed on Files - 2
name translation failed on (x86)\Cypress\PSOCDE~1\5.4\Common\CYPRES~1\tools\include\CY8C28~1 - 3
lib/psocconfig.asm
!E lib/psocconfig.asm(19): file 'm8c.inc' not found in current directory or in include path(s)
!E lib/psocconfig.asm(56): no such mnemonic 'RAM_PROLOGUE'
!E lib/psocconfig.asm(62): no such mnemonic 'RAM_EPILOGUE'
!E lib/psocconfig.asm(86): no such mnemonic 'RAM_PROLOGUE'
!E lib/psocconfig.asm(89): no such mnemonic 'M8C_SetBank0'
!E lib/psocconfig.asm(104): no such mnemonic 'M8C_SetBank0'
!E lib/psocconfig.asm(107): no such mnemonic 'RAM_EPILOGUE'
!E lib/psocconfig.asm(129): no such mnemonic 'RAM_PROLOGUE'
!E lib/psocconfig.asm(142): no such mnemonic 'M8C_SetBank0'
!E lib/psocconfig.asm(143): no such mnemonic 'M8C_ClearWDT'
!E lib/psocconfig.asm(152): no such mnemonic 'M8C_SetBank1'
!E lib/psocconfig.asm(172): no such mnemonic 'RAM_EPILOGUE'
make: *** [lib/obj/psocconfig.o] Error 1
make: *** Deleting file `lib/obj/psocconfig.o'
PDProject3 - 14 error(s) 0 warning(s) 19:48:04
i done lot of searing to find a solution for this problem...i tried all solution which i got from different discussion forums, but i have no luck..please help me to solve this
Hi...
Already i tried it...its not at sove my probleam...Before sending a mail to you..i done all the things ,which i got from google...
Thank's
Dinu wilson
Get Outlook for Android
Can you kindly attach your project?
Sampath Selvaraj
Hi...
how can i do it?...please tell me.the steps
Please kindly follow this procedure.
- Uninstall PSoC Designer 5.4
- Delete the directory C:\Program Files\Cypress\PSoC Designer\5.4
- From the Start menu, select Run.
- In the Run window, type cmd.
- In the DOS window, type fsutil behavior query disable8dot3
- If the result is disable8dot3 = 0 you are done.
- If the result is disable8dot3 = 1, type fsutil behavior set disable8dot3=0.
- Reboot the computer
- Install PSoC Designer 5.4 in the directory C:\Cypress
- Reboot the system
- Create a new empty project and check the build process
Hi...
i done it...no change.showinng same probleam
Try deleting the file "project.dep", and then rebuilding your project.
Sampath
