hi
I can not use the same hex file for programming Cy8c5666 and cy8c5667
do you know a solution for the issue. the customer what ONLY one file for programming
PSoC 5 Device Programming
PSoC 5LP
- programerase cycle
Hi Avihoo,
You can check the Silicon ID/ Device ID of any PSoC device by using PSoC Programmer and then giving any simple operation request like Erase All.
The silicon ID will appear like this in PSoC Programmer for the PSoC:
Ankita
Hello ,
The same hex file can't be used to program Cy8c5666 and cy8c5667 because there is a field Device ID in hex file which is unique to each part number. This is explained at page# 79 of this PSoC5LP Programming Spec available at this link:
https://www.cypress.com/file/119651/download
Ankita
Dear Ankita
Thanks for the answer, and in a second thought because the device is analog and code you must define the CPU in the hex file.
I will look at the data sheet thanks for the pointer
BR avihoo
Hi Avihoo,
Ankita
Hi Ankita
I have NO problem to read the device type and set the right device in the compiler.
We will update all the CPUs to the same one and will use only one HEX file for the programing
Thanks a lot
Avihoo keret
